Is it possible to use hot (L) wire in SW1 or SX
  • This is the way you would wire an older Shelly. This way it would be possible to use 2 - 2 way circuits without massive rewiring. I only use detached mode, and I already have L and N at the shelly.
    this way i can also use it for 2 - 2way circuits Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen.
    2 Mal editiert, zuletzt von Tight#Wildflower#24306 (9. Januar 2021 um 18:34)
  • looks like it should work, becuase i found this:
    I have read something other from a German member, he had test it.
    But you can test it again ?
    He said when you switch with L it isn't comprehensible what happen (on/ off)
  • I have a similar issue here. I tried to wire one switch through SX and the other through L and it acted quite erratically. Should I have wired both through L or N to make it act sane?
  • Shelly 1L inputs (SW) may be activated either with Sx potential or with O potential! N potential may be used (if it exists), but gives a significant raise of temperature in the Shelly if used with switches. Push button switching against neutral is o.k.
