Hello,
I have an issue with a Shelly Pro 2.
I wired it according to the wiring diagram, using a 1 MΩ resistor.
In the settings, it is correctly configured as Detached – Input is separated / not changing state of the output/relay, and the input type is set to Switch.
Here is what I observe:
- When the alarm is not activated, I measure about 50 V between earth (ground) and SW1.
- When the alarm is activated, the voltage rises to about 120 V between earth and SW1.
My electrical installation is 3 × 220 V.
The issue is the following:
- When I access the Shelly web interface (192.168.1......), without the alarm, the input is shown as OFF.
- With the alarm activated, the input still remains at 0 and does not change state.
I therefore do not understand why the input does not switch despite the measured voltage change.
Thank you in advance for your help.
Best regards,
Jean-Pierre
