Firmware 1.7 is comming on Monday
    • Autor
    We are ready to release FW1.7 there is change log which i will publish at Monday.
    Log changes:
    Shelly EM and Shelly3EM Overpower protection added
    Shelly EM and Shelly3EM Actions added
    Shelly EM and Shelly3EM user can reset total counters and delete all data
    Actions updated - devices can send actions to itself. To use that you need to input at URL field http://localhost/... for all comands check Shelly REST API.
    Gateway in internet settings is optional
    PlugS - MQTT topic for power consumption added
    Short and Long push updated to be suppored from scenes
    Auto On/Off countdown timer is supported from the Shelly App
    Dimmer Warm-up feaure added, device can send wake-up impulse controled by time and power to the bulb when brightness is low.
    Shelly1PM - user offset for power consumption is added and allow to calibrate device if needed.
    Shelly1/PM Temperature Add-on, sensord ID is added in device status and over MQTT
    Shelly Dimmer input debouce option is added in webUI
    Shelly Duo - countdown timer for Auto On/Off is added in REST
    Shelly Smoke - temperature offset added
    `User-Agent` request header for actions added
    Synchronisation between Cloud, REST and MQTT is improved which allow to set mutiple action URLs in next firmware (1.8)
    RGBW2 - huge update:
    After this update Shelly RGBW2 - Color and White mode is separated. Everytime when customer change mode, device update firmware with OTA. This is allow to have more Flash and RAM for current and fufure features.
    Actions added in Color and White mode
    Overall stability is improved significantly
    Amazon and Google integration improved
    Toggle command over MQTT added
    Bug fixes:
    Shelly1/PM Temperature Add-on, sometimes device stop reading temperture and humidity values
    Sometimes after reset devices not return to AP
    HTTP Login: max length of fields is fixed
    Shelly 2.5 and Dimmer temperature measurement incorrect in certain conditions which can cause fake over temperature protection
    Duo: Inconsistent JSON type
    Backup Static IP cannot be removed
    Security issue: Passwords are returned in plain format (settings)
    Empty user/pass can be set but but this cause login issues
    Duo forgets mode when controlled over MQTT
    Some text in webUI is improved.
    Another minor bugs are fixed
  • Frei Übersetzt:
    Wir sind bereit, FW1.7 zu veröffentlichen. Es gibt ein Änderungsprotokoll, das ich am Montag veröffentlichen werde.
    Protokolländerungen:
    Shelly EM und Shelly3EM Overpower-Schutz hinzugefügt
    Shelly EM- und Shelly3EM-Aktionen hinzugefügt
    Shelly EM- und Shelly3EM-Benutzer können die Gesamtzahl der Zähler zurücksetzen und alle Daten löschen
    Aktualisierte Aktionen - Geräte können Aktionen an sich selbst senden. Um dies zu verwenden, müssen Sie im URL-Feld http: // localhost / ... für alle Befehle die Shelly REST-API überprüfen.
    Das Gateway in den Interneteinstellungen ist optional
    PlugS - MQTT-Thema für den Stromverbrauch hinzugefügt
    Short and Long Push aktualisiert, um von Szenen unterstützt zu werden
    Der automatische Countdown-Timer für Ein / Aus wird von der Shelly App unterstützt
    Dimmer Aufwärmfunktion hinzugefügt, kann das Gerät einen Weckimpuls senden, der durch Zeit und Leistung gesteuert wird, wenn die Helligkeit niedrig ist.
    Shelly1PM - Der Benutzeroffset für den Stromverbrauch wird hinzugefügt und ermöglicht die Kalibrierung des Geräts bei Bedarf.
    Shelly1 / PM Temperature Add-on, Sensord ID wird im Gerätestatus und über MQTT hinzugefügt
    Die Shelly Dimmer-Eingabe-Debouce-Option wurde in der webUI hinzugefügt
    Shelly Duo - Countdown-Timer für Auto On / Off wird in REST hinzugefügt
    Shelly Smoke - Temperaturversatz hinzugefügt
    Anforderungsheader "User-Agent" für hinzugefügte Aktionen
    Die Synchronisation zwischen Cloud, REST und MQTT wurde verbessert, sodass in der nächsten Firmware URLs mit mehreren Aktionen festgelegt werden können (1.8).
    RGBW2 - riesiges Update:
    Nach diesem Update wird Shelly RGBW2 - Farb- und Weißmodus getrennt. Jedes Mal, wenn der Kunde den Modus wechselt, aktualisiert das Gerät die Firmware mit OTA. Dies ermöglicht mehr Flash und RAM für aktuelle und zukünftige Funktionen.
    Im Farb- und Weißmodus hinzugefügte Aktionen
    Die Gesamtstabilität wird deutlich verbessert
    Die Integration von Amazon und Google wurde verbessert
    Befehl umschalten über MQTT hinzugefügt
    Fehlerbehebung:
    Shelly1 / PM Temperature Add-on, manchmal hört das Gerät auf, Temperatur- und Feuchtigkeitswerte zu lesen
    Manchmal kehren Geräte nach dem Zurücksetzen nicht zum AP zurück
    HTTP-Anmeldung: Die maximale Länge der Felder ist festgelegt
    Shelly 2.5- und Dimmer-Temperaturmessung unter bestimmten Bedingungen falsch, was zu einem falschen Übertemperaturschutz führen kann
    Duo: Inkonsistenter JSON-Typ
    Statische Sicherungs-IP kann nicht entfernt werden
    Sicherheitsproblem: Passwörter werden im Nur-Format zurückgegeben (Einstellungen)
    Es kann ein leerer Benutzer / Pass festgelegt werden, dies führt jedoch zu Anmeldeproblemen
    Duo vergisst den Modus, wenn es über MQTT gesteuert wird
    Einige Texte in der WebUI wurden verbessert.
    Weitere kleinere Fehler wurden behoben
  • Hello, it seems a lot of improvements are comming in the 1.7.
    I am not lucky, that the issues,
    with same SSID across more than one AccessPoints were shelly search for the lowest channel an not the the best Signal from AP is NOT fixed.
    Or have I overreading this fix here?
    Br
    Jochen
    In Betrieb :9xShelly1, 3xShelly 2.5, 3xShellyplus2PM, 8xShelly HT, 6xShelly Plug S, 2xShelly 1PM, 3xShelly Plug, 7xShelly Button1, 1xShelly TRV, 2xShelly H&T Plus, 1xShelly1 plus mit AddOn Modul, 2xShelly Flood
    Als Spare: Shelly2.5, Shelly 1, Shelly1PM, ShellyPlugS, ShellyH&T, ShellyPlug, Shelly1plus, Shelly1PM plus, AddOn Modul
    Addons: Smarthome via Openhab 5..1.3-1@Raspberry PI 5, Backup PI 4, DEV mit PI 4, 8x TP-Link HS110, Broadlink RM4mini, ASAIR AM2301A, HA PI4, 2 x MyStrom Button
  • alle Update durchgelaufen, bisher keine Probleme
    Was hier noch ganz wichtig zu erwähnen ist, das beim Update des RGBW2 auf FW 1.7 kein Downgrade mehr möglich ist über OTA Befehl auf niedrigere FW.
    Euch soll das nicht unbedingt abhalten das FW durchzuführen, weil durch die getrrennnte FW viel mehr Optionen möglich sind, aber im Hinterkopf solltet ihr es haben.
    Wenn man Flasht kann man zurück auf älter FW.
    Betrifft nur den RGBW2.
  • Dieses Thema enthält 105 weitere Beiträge, die nur für registrierte Benutzer sichtbar sind.
