Shelly Em not working [returned device]
  • My 8 months old Shelly EM is not returning any Kwh or V and the json returned by the "status" endpoint looks like this:
    In both emeters "is_valid" is False, so is it dead? any way to fix it? a factory reset , a downgrade of firmware or using other power supply did not work.
    Really sad that it did not last a year.
    Thanks for your comments!
    2 Mal editiert, zuletzt von Manuel.na82 (27. Juli 2023 um 09:36)
  • Can you send us the settings:
    http://<shellyip>/settings
    And please add the Output in a code box for better reading
  • Hi, sure, here are the settings:
    2 Mal editiert, zuletzt von Manuel.na82 (27. Juli 2023 um 09:18)
  • With the clamps disconnected, the volts between P1/P1+ and P2/P2+ is 0V , so it looks like there is no power in the clamp pins.
    Anyway to get the shelly alive again?
    Is this also normal?
    "hwinfo": { "hw_revision": "dev-prototype", "batch_id": 0 }
    dev-prototype ??? I saw other shelly em's showing the manufacture date.
    Einmal editiert, zuletzt von Manuel.na82 (27. Juli 2023 um 10:33)
  • This is ok and no sign of a faulty Shelly! Would it be possible to measure the resistance between P1+ and P1-, respectively P2+ and P2-? Meter should read 10 Ohms...
    Pay attention, please! Ohms measurement with detached Shelly only!
