Shelly 2.5 toggle switch question.
  • Hi All
    First of all I am new to Shelly.cloud but I have used other relay solution in the past.
    I have a question about using a toggle switch with a Shelly 2.5. I have installed the relay to a light switch but the behaviour is different to what I am used to. I wondered if this was the correct behaviour for a Shelly relay or if the behaviour could be changed to act like my other brand relays?
    I am using a toggle switch and while the switch is in the off position I can switch the lights on or off using the app but if I switch the app on using the app and want to switch it back off using the switch, I have to flick the toggle to the on position and then off again and via vera. Is there a way where you only have to toggle the switch once? This is how it works with a Zigbee relay module I have.
    Thanks in advance. Let me know if you have any questions.
  • „Restore last mode“ would be the appropriate setting for power on default.
