Shelly Pro 2 wiring without switch
  • Hi there,
    I'm new to Shelly products and community !
    I've bought a Shelly Pro 2 in order to control 2 lines of LED lights in my garden.
    I just need to be able to control the lights (2 different lines of lights) from the Shelly. I don't want to have a switch nor something physical to install.
    When the Shelly is only connected to L + N (at the bottom), I can control the output. I can ear the relay switching.
    But, If I follow the wiring diagram, the light is ON by default and if I try to turn it OFF, the the power is cut in the main board !
    Where can I find some wiring exemple ? (I'm not a professional electrician !)
    Thanks a lot for your help
    Julien
    • Hilfreichste Antwort
    You can find the connection diagram here:
    Think of the switches away in the scheme
  • magicju 7. September 2022 um 15:55
    Hat einen Beitrag als hilfreichste Antwort ausgewählt.
