Response Wert source = input, switch, http usw
  • der Aufruf der Shelly IP gefolgt von /status ergibt nachfolgenden Response
    Hinweis:
    1.Generation: http://192.168.178.150/status
    2.Generation: http://192.168.178.150/rpc/shelly.getstatus
    1.Generation
    wifi_sta connected true ssid "wlan ssid" ip "192.168.178.99" rssi -52 cloud enabled true connected true mqtt connected false time "06:48" unixtime 1648702102 serial 1531 has_update false mac "123456789012" cfg_changed_cnt 1 actions_stats skipped 0 relays 0 ison false has_timer false timer_started 0 timer_duration 0 timer_remaining 0 source "cloud" meters 0 power 0 is_valid true inputs 0 input 1 event "" event_cnt 0 ext_sensors {} ext_temperature {} ext_humidity {} update status "idle" has_update false new_version "20220209-092750/v1.11.8-g8c7bb8d" old_version "20220209-092750/v1.11.8-g8c7bb8d" ram_total 50864 ram_free 38568 fs_size 233681 fs_free 149847 uptime 1293594
    2.Generaion
    ble{}cloudconnectedtrueinput:0id0statenullmqttconnectedtrueswitch:0id0source"init"outputfalseapower0voltage233.1current0aenergytotal0by_minute001020minute_ts1648702939temperaturetC44.3tF111.8sysmac"123456789012"restart_requiredfalsetime"07:02"unixtime1648702942uptime7701ram_size239396ram_free163412fs_size458752fs_free217088cfg_rev36available_updatesstableversion"0.10.1"wifista_ip"192.168.178.111"status"got ip"ssid"wlan ssid"rssi-65
    Der Rückgabewert "source" teilt den zu letzt erteilten Befehl mit.
    Hierbei gibt es aber einer Unterschied zwischen Geräten der 1. und der 2. Generation
    1.Generation: (shelly1v3, 1PM, 2.5, Dimmer ...)
    source = http : Webinterface Switch (Browser Schalter), Befehl per RestfullApi oder mqtt
    source = cloud / CLD : Befehl per App erteilt
    source = timer : On & Off Timer
    source = schedule : Weekly Schedule
    source = init : nach Reboot
    2. Generation (shelly Plus1, 1PM, 2 ...)
    source = http : per App im Wlan
    source = SHC : Shelly Cloud (per App im Mobilnetz)
    source = WS_in : Webinterface Switch (Browser Schalter)
    source = switch : Schalter an SW (Flip / Follow [Switch])
    source = button : Taster an SW (Momentary [Button])
    source = MQTT : mqtt Broker z.B iobroker
    source = loopback : Weekly Schedule
    weitere Erkenntnisse werden ergänzt
  • merkwürdiger Weise bekomme ich kein Source beim Shelly1v3 beim Schalter (SW) , http oder cloud wird angezeigt.
  • Das Aktivieren des SW-Eingangs wird über den Parameter „input“:1 angezeigt. Ist Button Type „momentary“ eingestellt, wird zusätzlich mit dem Parameter „event“:“L“ oder „event“:“S“ die Länge des Tastendrucks gemeldet. In allen Fällen wird der Parameter „event_cnt“:<n> aktualisiert. <n> ist eine Zahl, die mit jedem Tastendruck hochgezählt wird.
    Ist ein Taster an SW angeschlossen, ist „input“: 1 nur für die Dauer des Tastendrucks gesetzt - beim loslassen der Taste geht der Wert auf 0 zurück.
    Der Parameter „source“ bleibt unverändert, wenn über SW geschaltet wird und zeigt an, woher der letzte Software-Befehl kam (siehe oben).
