Hi,
I have a Shelly RGBW2 and I would like to control the dimming through the momentary button, but with a brightness range from 1% to 85%.
How can I do this?
Best regards
Hi,
How can I do this?
Best regards
Unfortunately there is no such function with Shelly Software. Only minimum brightness can be set, but not max.
Maximum brightness could be set via an adjustment of the external power supply: For a 12V LED strip approximately 11V DC.
How can this be set in the RGBW2? I would like to have a minimum brightness, it's too easy to dim lights below their minimum and then it's very confusing to dim lights up again.
I can't find a minimum setting anywhere in color or white mode with fw 1.12
Please excuse me. This is not possible with the RGBW 2. I was confused here with Shelly Dimmer.
