Why is L connected to the ground pin?
  • I have noticed by using a multimeter that the L (as in "live wire", I assume) is connected to the ground pin the header on the Shelly1. If we use an usb serial adapter plugged to a computer to communicate with the ESP in the Shelly, isn't there a good chance that connecting the ground of the usb adapter to the Shelly1 would cause a short circuit and potentially burn the computer?
  • Right! You MUST supply your Shelly with 12V DC (e.g. with a wall power supply) if you want to flash with an USB adapter.
  • Sorry - didn’t double check this cause it seemed naturally in my eyes. But others will give you an answer to this question, I’m sure…
    Einmal editiert, zuletzt von thgoebel (20. September 2021 um 19:54)
