I3 on a PARADOX security system?
  • Hi,
    Idea is that I would like to put i3 on a old PARADOX security system that basically has 3 sensors that are directly connected to the main system with cable.
    i guess the sensor sends the signal to the box via the cable.
    i would basically connect the 3 lines to 3 output cables from the sensors and see if the i3 would detect the change and report so i could expand the security system form just a local alarm to alert to be able to receive the notifications via home assistant.
    could this work??
    any way i will try it at some point and report the results, but u guess it all boils down to the type of the signal the sensors send and the level of the current
  • I also want to use a i3 as an alarm system interface but there is a restriction with the i3. This issue is that the its voltage range is 24-60VDC but the paradox systems runs on 12V. A solution to powering the i3 is to use a step up module like this from eBay:
    MT3608 DC-DC Step-Up Converter Booster Power Supply Boost Board
    12V in / 24V out.
    But I'm not sure how the i3 will interface with the PIR zones.
    Let me know if anyone has more info on the i3 trigger inputs.
    Glenn
  • With some skills in electronics (or with a friend who owns this knowledge) it would be possible to supply a Shelly i3 with 12V DC:
    DIYROLLY
    12. November 2021 um 18:23
    Could imagine to send you such a modified part - please send PM if interested…
  • Paradox wired systems work with change in resistance. Usually there are resistors in the sensor and if everything is ok the resistance on the signal cable is constant. At any event the resistance is changed. For the tampering alarm I think the state is infinite resistance, but I'm not sure about that. If you have full control over the security system you can check inside the sensor. BUT if you open the sensor when the system is with power, it will trigger the tamper alarm no mather if it's armed or not.
    Usually the resistance is around 200k-400k. There are installation guides that are proposing the usually used values, but I think the main reason for this approach is to be flexible and be able to use your own values during the programming state.
    Most Paradox systems have programmable PGMs, so if you have programming access you can use them. This way you can have separate power supply, which is the best ways when you connect to a security system.
