night mode
  • Can someone explain how the "night mode" should work?
    I'm using a shelly duo in my bathroom with a conventional switch (cuts the power)
    My expectation is that if I switch the bulb - using the physical switch on the wall:
    - the bulb boots up,
    - checking the time,
    - using the last settings - if outside of the nigh mode schedule.
    - using the night mode settings - if inside the night schedule.
    In practice it is just not work this way, it is always using the last settings.
  • Das geht nur wenn die Lampe dauerhaft versorgt wird. Nach dem einschalten wird erst WLAN aktiviert, Zeit synchronisiert und der schedule Befehl ist dann vielleicht nicht mehr gültig.
  • So, this is a bug or works as designed? :)
    For me - in case of a socket E27 bulb - features working only if 'always powered' is pretty much useless.
    Einmal editiert, zuletzt von Zrubi (23. Januar 2021 um 16:09)
    Fully agreed. This doesn't work. It can't be really used well in the cut-off mode. I also thought that this works, but was disappointed after finding out.
