Hi -
Just getting started with my first Shelly device. So far I'm really impressed with the size, functionality, price, etc.
I would like to understand the SW input in more detail. All documentation I can find indicates that this input should be left floating (disconnected) for logic zero or brought to the same level as the L input for logic one. But I would like to understand the operation in more detail.
Is SW a digital input with a specific threshold voltage? If I am powering the SW with an external signal (from a sensor or raspberry pi) can I drive the input high with the other device's digital output, or must it truly be connected with a relay to the Shelly power supply voltage, regardless of whether that voltage is 120V, 12V, 40V, etc.
Thanks![]()
