Dimmer 2 as the 3 way
  • What is the proper wiring diagram to do the following:
    I have two 3 way toggle (on/off) switches. I want to remove one of those three way switches and put the Shelley dimmer 2 in its place.
    The goal is to: turn the light on and off with shelly and still be able to turn the lights on and off with the toggle switch.
    • If I use the toggle switch will it turn on at the last setting?
    • If the toggle switch is off will the shelly still be able to turn the light on?
    • I should have one, but if a neutral is not directly accessible can I connect the N of shelley to my shared common ground back to the bus on the load center to avoid installing a bypass?
    Thank you!
  • A diagram with this type of switches is shown here. Please be aware that the two switches allow on/off only - dimming has to be executed via the WebUI, the cloud or a home automation system!
