Frequency of wake ups
  • Hi guys,
    I just purchased a shelly H&T. I'm on the latest version 1.8.0.
    I was hoping to have the ability to set the frequency of the wakeups/reports, and this is what I can read in the manual.
    "Send Status Period: Define the period (in hours), in which
    Shelly H&T will report its’ status. Possible range: 1 ~ 24 h."
    I can't find this parameter, neither on the shelly app or by connecting directly to the webserver of the device.
    Currently I get a reading of the TEmperature every.. 6 or 8 hours.
    I'm on battery.
    I'm quite disappointed.
    I have an aqara temp sensor (as well) and I get very frequent readings and nice graphs showing me small temp differences.
    Einmal editiert, zuletzt von cgail914 (15. Oktober 2020 um 07:07)
    This feature has been removed by Allterco to save battery power.
    The Shelly wakes up according to the stored settings for Temperature Thresshold, or Humidity Thresshold.
  • MIHO : Thx, I figured. I understand they problably had battery life issue, but to some extend I would leave the choice to the user.
    Default : threshold mode : ie. if TEmp moves by 0.5 or more, wake up.
    Forced by user : wake up every x hours, which they had implemented anyway.
    Some users may be ready to change the battery every 3 months to get more readings.. User choice.
    I imagine (actually I hope) that if the Shelly T&H is supplied with power, I do get readings every 10min ?
    • Hilfreichste Antwort
    Yes, it works with the Power Supply.
    Under Sensor Settings, activate external power supply. Then it wakes up about every 10mim and reports the values
