Shelly RGBW2 Dimming via Wall Switch
  • Hi,
    I am looking to buy the RGBW controller but am having trouble understanding how to wire this to a wall switch.
    In the wiring diagrams it shows a wall switch as on/off/dimming. See the attachment.
    Does this mean that if the wall switch has a Shelly Dimmer 2 and this is connected to the RGBW I/O as pictured, will dim the Led Strip lights?
    I.e. The dim function from the Dimmer 2 is received by the RGBW which in turn dims the lights
    Just a bit confusing as to what "Dimming" means at the wall switch.
    My goal is to be able to turn the led lights on and off as well as dim from the wall switch (push button)
    • Hilfreichste Antwort
    Welcome to the Forum ??
    You do not need an extra Shelly dimmer on the button.
    A normal push button is completely sufficient, and with it you can
    short keying = on/off
    hold down = dims up
    press and hold again = dims down
    control the RGBW2 from there.
  • I am not able to change button type to Momentary. It freezes app, I have to restart it and I always found the same value for button type which is toggle switch. Any advice ?
  • Is posible with 4 withe strips and rgbw2
    short keying = on/off n1 n2
    Long keying = on/off n3 n4
    Or similar?
    Thanks
