Shelly 4Pro Firmware Update Problem
  • Hi,
    I have an issue with a 4Pro that I had lying arround for a while. The problem is that it does not find any newer firmware even though its firmware is very old. All I see is:
    The current Firmware version of your Shelly device is 20190130-082102/??? No newer firmware available.
    What can I do? Is there any way to force a firmware update?
    My Shellies: 15x 2,5 / 3xRGB / 2x 1 / 2xEM / 3x4Pro / 4x3EM / 4xi3 / 20x Duo RGBW E27, 10x Duo RGBW G10
    Welcome to the Forum ??
    The 4Pro has secure Internet access?
    Another possibility would be via OTA command.
    Have a look at our Firmware Archive:
    https://shelly-forum.com/index.php?shelly-firmware-archive/
  • Thank you for the info...
    I did have some issues though... The update worked fine, but afterwards the device was not working well... When saving settings I got errors or sometimes it would say that it could not fetch the device settings... I went though a few cycles of factory resets and flashing different versions of the firmware.
    Then for a while setting a fixed IP resulted in the device not connecting to WiFi anymore...
    Anyway now I did get everything flashed and working, but I am not sure if the deivce is really fully functional, or if there is an issue... I also had a situation where some parts of the display were not correct... (like invalid data in the flash or memory...)
    Where did you get such information?
