Email Notifications
  • Hello,
    And once again, thank you for your answers — everything is now working perfectly.
    I currently have a Shelly Pro 1 with the SW1 and SW2 inputs.
    SW1 is used exclusively to send me an email when a solenoid valve, controlled by an Easy Level relay, closes.
    👉 This works perfectly.
    My question is the following:
    👉 Is it possible to do the same with SW2, so that it sends me an email when the booster pump starts?
    ⚠️ Important clarification:
    • The booster pump is controlled by a Toscano TPM 7 Pump module.
    • The pressure switch that triggers the pumping request is connected to the D terminals of the TPM 7 module.
    In addition, I would like to add a second Shelly Pro 1 to receive an email:
    • when the level in my tank is too low,
    • and when it is too high.
    Regarding the levels:
    • I have a float switch connected to the E terminals of the TPM 7 module.
    I am attaching a photo of the TPM 7 module to illustrate my installation.
    Thank you in advance for your help and advice.
  • (a) Check, if input SW2 is detached (WebUI):
    This should be true cause SW1 is used for another purpose.
    (b) Create scene in Shelly App
    Click plus sign.
    Click „add condition“
    Click „Create Condition“
    Select room which hosts the Shelly pro 1 device:
    Select device:
    Select „Input State“:
    Select „ON state“ as trigger:
    Select „Trigger“:
    (Follow-up in next port due to limitation of pictures.)
  • (Follow-up)
    „When“ condition is now complete…
    Select „Do“ action: Notification:
    Select the appropriate type of notification:
    Select active time (if necessary):
    Select room which should host the scene (or use „global“):
    Give the scene an appropriate title:
    …and save!
    Test the scene:
    (Follow up with wiring proposal…)
    Dateien
  • (Follow-up)
    Wiring could be as following:
    Due to the fact that SW2 is triggered with neutral potential which would dissipate about 300mW in the Shelly device, a resistor is added to reduce the power dissipation to 14-28mW. Please be careful in mounting the resistor: It should be thoroughly isolated against involuntary contact!
