Thermostat Mode but still using Relais for button
  • Hello,
    I am currently testing the Shelly Wall Display and I am a bit lost.
    I have several Wi-Fi thermostats at home and I want to use the Shelly Wall Display as a physical switch for my lights, while simultaneously using its thermostat interface to control my wireless thermostats via Home Assistant.
    The issue is that whenever I switch the device to 'Thermostat Mode', I lose the ability to use the light button. Is it possible to decouple these functions so the button still toggles the relay while the display stays in thermostat mode?
    Example:
    http://10.10.10.10/rpc/Switch.Toggle?id=0
    {"code":-109,"message":"Method Switch.Toggle failed: Can not control when used as actuator in thermostat."}
    Best regards, Sam
