My Shelly Plug S V1 is not reporting power as negative despite having the correct device type selected.
Plug not reporting power as negative despite genrating source being selcted
- Shelly Plug S
Invicta -
25. Oktober 2025 um 12:52 -
Unerledigt
Shelly PlugS (Generation 1) cannot determine the direction of power flow! Thus, negative power isn’t within the parameters of the device.
Ah, thanks. I rather stupidly thought it would be since my tow external Shelly Plug S both record flow direction.
Could you tell me which plugs would measure power positive or negative? Does it need to be gen 3?
Yes, it must be a Shelly PlugS Gen3, which has a BL0942 „Energy Meter“ Chip. Generation 1 and 2 („Plus PlugS“) are equipped with a BL0937 chip, which isn’t able to report the direction of the power flow.
Dieses Thema enthält einen weiteren Beitrag, der nur für registrierte Benutzer sichtbar ist.
