How to connect shelly 1 mini gen 3 to a 3 phase network without neutral
  • I live in Belgium and I have 3 x 230V, without neutral, this means that behind every switch I have a combination of L1 , L2 and L3.
    How can I connect Shelly 1 mini gen 3 behind the switch to control the lights?
    thanks in advance for any help you can provide.
  • The N terminal of the Shelly must be wired to the same phase at which the consumer is wired which should be controlled. The L terminal to the same phase at which the manual switch is wired.
    Shelly and consumer should handle TWO phases ONLY!
