Shelly Pro 3EM and 4th clamp/CT on N/PEN
  • I have Shelly Pro 3EM 120A (gen2)
    see knowledge-base/shelly-pro-3em.
    I bought an additional split-core current transformer, Shelly CT 120A,
    • SHELLY SP3D-1121
    • EAN/GTIN: 3800235266410
    I plug all 4 CTs and all 4 wires.
    I can access the device
    • locally via its IPv4
    • via Home Assistant and its Shelly integration
    • via Shelly Cloud (app and page)
    I see current on phases A/B/C, but I do not see any value of N/PEN.
    What is wrong there?
    Should I activate some additional settings in the configuration to make N/PEN visible? And where?
    Does N/PEN measuring work for anybody?
  • Did you calibrate the CT at neutral wire (IN)? This must be done to get figures of current in neutral wire (other figures are not available.
  • When I choose local IP of Shelly Pro 3EM
    export SHELLY_IPV4='<MY_LOCAL_IP>'
    then I see the status via command
    curl --silent --request POST --data '{"id":1,"method":"Shelly.GetStatus"}' http://${SHELLY_IPV4}/rpc | jq '.result.sys'
    Similarly, I can see the configuration via the command
    curl --silent --request POST  --data '{"id":1, "method":"EM.GetConfig", "params":{"id":0}}'  http://${SHELLY_IPV4}/rpc | jq '.result'
    And when I want to see current values, then I use the command
    curl --silent --request POST --data '{"id":1,"method":"Shelly.GetStatus"}'  http://${SHELLY_IPV4}/rpc | jq '.result."em:0"'
    where I see a non-zero value for a_current` but null value for n_current.
