Shelly 1 inverted behavior
  • Hello,
    we have a device with a 12V controller.
    The controller has 2 contacts (normally open).
    If the contacts are open, the device is enabled (ON).
    If the contacts are closed, the device is disabled (OFF).
    If I use Shelly 1 to open / close the contact, it works, but:
    - when I see ON in the App, our device is OFF because the contacts are closed;
    - when I see OFF in the App, our device is ON because the contacts are open.
    Is there any tricky to invert this behaviour in the App?
    Thank you
    Hello @mirko.cola, welcome to the forum. ??
    Reverse input under Buttontype might solve your problem.?
  • Hi, thank you for your answer.
    I have tried, but it is the same.
    I think the "Button Type" settings in the App are related to the button connected to SW contact of Shelly.
    I have connected only I and O, there is nothing on SW.
