Shelly 1PM: in doubt of wiring
  • Hello
    The official wiring is as below, where one would think you need a wago 3 pins connector to connect the three N-wires.
    But I wonder if the wiring below does the same. It wouldn't need any wago connector and so the wiring seems more easy to me.
  • The last diagram may be used (with caution!) if the wattage of the appliance is lower than 1kW. Thus, Shelly goes the simple and easy way and recommends always to use only one of the N terminals.
  • Thank you that info! I'll go for the recommended way :-).
    What happens if you use the two N terminals for charging laptop, desk lamp, ... But you forget about the limit and start to use an electrical heater. Will the Shelly shut itself down or will it be dangerously?
