Power factor low at night
  • I'm using a Shelly 3EM (**Mod Edit**) Shelly 3EM-63W Gen 3 to measure my PV solar panel energy. During the day this seems to work well, if the sun shines, it gives me a high incoming power, if a cloud appears, it shows less power, so far so good. However, at evening and night there is power reported by the different phases, reaching powers of 1kW. During the evening and night there is also a low power factor for each phase. Seems that once there isn't a lot of solar, the system reports rubbish. I made sure that the clamps are mounted correctly and this also shows with a clear power factor of 0.99 or 1 during the day. I'm afraid it might be interference from the breaker box but want to make sure I'm not overlooking anything. Any ideas?
  • Would you please double check the correct wiring? This may be done as following:
    Execute this measurement (or let it be done by your electrician) for each phase!
  • Hi,
    Thank you for your response. As I have the Shelly 3EM 63 Gen 3 and the Va, Vb, Vc wires are connected correctly, I believe this should already be correct since the Va cable is put into the same 'hole' as the cable the clamp sits around, right?
  • Why did you post in Shelly 3EM category?
    Which type of Shelly 3EM-63 Gen3 do you own? The W-type or the T-Type?
    2 Mal editiert, zuletzt von thgoebel (29. Juni 2025 um 13:52)
