The switched current is the same: 16 A. DIN rail is advantageous, but for 50EUR?
Shelly Pro 1 is 3 times pricier. Is it about ethernet connection? heat management?
You did enumerate nearly all benefits of the pro version. It’s your turn to evaluate the prices!
In addition, the non-Pro Shellys are not permitted to be used “ loosely” in an UV.
At the very least, you will need an additional DIN-rail holder (with the appropriate fire protection class).
