Shelly Display - Unable to access Home Assistant
  • Upgraded firmware to 2.3.6 installed Home Assistant but unable to determine how to connect? Do i need to install Home Assistant on a separate device ? I thouhgt i installed the Home assistant on the Wall Display?
    Any help would be grateful...
  • Of course, you need a server (e.g., RaspiPi or similar) where Home Assistant runs. Then you can set the address of the Home Assistant system in the wall display and use it on the wall display.
