Shelly 3EM one negative phase
  • I’ve just had a 3em installed and am getting a negative reading on phase 1 when there is no load. When I turn on my 3p bore pump all phases show with positive values in the right range, so the current clamps are correct. I have double checked the clamps and voltage wiring is correct to the right and matching phase. Is this now a calibration issue? I understand they should be calibrated from factory.
    No load reading
    Bore pump operation
    Switchboard wiring
  • A power factor of -0,3 indicates a small capacitive reactive power which may be caused by RFI components with a consumer in idle state. This has to be ignored.
