Shelly 0-10V and Mean Well ELG LED driver compatibility
  • Hi,
    which Shelly 0-10V dimmer do i need to pick if i want to control a Mean Well ELG LED driver?
    Despite having some background in electronics, I find all the information somewhat confusing.
    Looking into the details of the Gen2 and Gen3 0-10V dimmers, it says Gen2 = current sinking and Gen3 = current sourcing
    Looking at the documentation of the meanwell dimming methods, it says that the controling device can be passive (voltage divider i assume), active (0-10V) or PWM. Also there is a mention of the driver sourcing 0.1mA of current.
    https://www.meanwell.eu/ExclusivePDF/DIMMING-NOTE.pdf
    Now what does that mean exactly. If i assume the driver is sourcing 0.1mA i would conclude that i need the Shelly Gen2 which is current sinking.
    On the other hand if i assume that the driver is controlled by an active dimming device and the dimmer would provide the 0-10V, wouldn't that mean the dimmer would provide the current as well? So then it'd be the Shelly Gen3?
    Does somebody use one of the 0-10V dimmers with a Mean Well ELG driver? Or can somebody point me to a straight-forward and well working combination?
  • Shelly plus Dimmer 0-10V has an optocoupler output (PC817) forming a PWM current sink. On the other hand, the Shelly Dimmer 0/1-10V PM Gen3 delivers a smooth DC voltage between 0 to 10V. This is the main difference between these parts. Suggest to use the Gen3 device if the manual of the appliance to be dimmed does not explicitly mention PWM capability…
  • Actually the Mean Well documentation also mentions PWM support (resistor/PWM/0-10V). So both should actually work?
    TBH now i'm even more confused by the terminology. So 0-10V can actually also be a PWM signal despite its name suggesting an analog behaviour?
  • The Shelly plus Dimmer 0-10V has a PWM sink only. No DC voltage at the output…
    Some stuff to read:
    thgoebel
    18. November 2023 um 19:32
    On the other hand the Gen3 device:
    thgoebel
    21. Juni 2024 um 17:05
