Hi Shelly developers, since I have many double windows with dual Shutter motors, Relais for each Shuttermotor are already in use.
Problem description:
The automatic positon calibration is failing because the Shutter motorpower cannot be detected when using Shuttermotor Relais.
The only solution:
A Shelly 2.5 Firmware extension for manual position Calibration is needed.
Please give me a feedback if you will provide a Firmware update.
I could support you on System specifaction level.
You can also answer in German !
Regards
Peter
