Can the i4 Gen3 be operated on 24 volts DC?
  • The Shelly plus i4 should run with 24V DC. Plus at pin N, minus/GND at pin L.
    thgoebel
    26. Januar 2022 um 12:10
  • Sorry if i wasn't clear. I was asking about the new I4 Gen3 version. I knew about the Plus I4 teardown. Perhaps you are saying that it's equivalent in this way to the Plus I4.
  • It is the same (except the CPU). Thus, it should also work with 24V DC…
