Hi, I have this need
By pressing a button 5 times, you should sequentially activate Input 1 then Input 2 then Input 3 then Input 4 and finally turn everything off
It's possible?
Many thanks for your support ![]()
It's possible?
Welcome to the forum!
Please have a look at the embedded script library (in each generation 2 Shelly):
This should meet your requirements!
Thank you very much . It was what I was looking for
Could you just tell me how I can change this string to make it work?
[0 1 2 3, "off"],
I have to close the loop by turning off all inputs
Thank you again
let CONFIG = {
* Pick your desired Input to be used for triggering the cycling (note: this input would be changed
* to detached!)
INPUT_ID: 0,
* List (in the expected order) the operations that you want this script to cycle through.
* E.g. [switchId, "on" or "off"]
CYCLES: [
[0, "on"],
[1, "on"],
[2, "on"],
[3, "on"],
[0 1 2 3, "off"],
let currentCycle = 0;
let runCycle = function () {
let currentOperation = CONFIG.CYCLES[currentCycle];
if (!currentOperation) {
currentCycle = 0;
currentCycle++;
Shelly.call("switch.set", {
on: currentOperation[1] === "on",
let setup = function () {
Shelly.call(
"switch.setconfig",
{ id: JSON.stringify(CONFIG.INPUT_ID), config: { in_mode: "detached" } },
function () {
Shelly.addEventHandler(function (event) {
if (event.component === "input:" + JSON.stringify(CONFIG.INPUT_ID)) {
if (
event.info.state !== false &&
event.info.event !== "btn_up" &&
event.info.event !== "btn_down"
runCycle();
}, null);
setup();
Alles anzeigen
I’m a novice in scripting, but I would assume the example does the following:
1st press of the (single) button: Turn output 1 on
2nd press: Turn output 2 on, leaving output 1 on
3rd press: Turn output 3 on, leaving output 1 and 2 on
4th press: Turn output 1 to 3 off.
You may alter each of the four lines according to your needs!
I added this line of code but it is incorrect
I need a hand to write it correctly
