Transformator Smart machen
  • Hello there,
    Any suggestions on how to make a transformer like this „shelly-smart“? Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen.
    Planning to run a ventilator with various different volt and therefore speeds.
    Thanks for any suggestions.
  • I would try the following.
    Equipment
    1. one Shelly Pro 4 PM or
    2. two Shelly Plus 2 PM
    I would code a script that ensures that only one of the four outputs is switched on at a time. As soon as you want to switch, all outputs can be switched off for safety reasons and then the desired output can be switched on.
    I don't know if this can be imlemented without a script.
    Edit: After a reboot, all outputs must be configured to “off”.
    Edit 2:
    I mistakenly saw the 80V connection being used. Of course, three outputs are sufficient.
    Compared to the electrically safe series connection of relay outputs ( thgoebel), my script solution uses slightly less energy... ;)
    Einmal editiert, zuletzt von eiche (14. April 2024 um 19:15)
  • In theory, you could do this with 3 relays. However, the 3 relays must be interlocked against each other.
    In practice, I would advise against such tinkering and will therefore not provide any further information.
  • Welcome to the forum!
    To your issue: It is absolutely essential to switch one tap of the autotransformer only to the ventilation motor. Two tap must not be connected together cause the transformer would be damaged. Thus, I would recommend to use three or four NO/NC relays, like these:
    https://www.amazon.de/Eltako-2078023…aps%2C93&sr=8-7
    Connected with this circuit diagram
    each tap is switched exclusively to the motor. You may use a Shelly pro 3 for three speeds or a Shelly plus 4PM for four speeds.
    Please be aware to place three or four snubbers in parallel to the relay coils. If a Shelly pro 4PM shall be used, NO power measurement will be available cause the Shelly indicates the power consumption of the relay coil(s).
    A separate on/off switch can be implemented with the fourth contact of a Shelly pro 4PM or a single Shelly plus 1PM, which can be used for power monitoring:
    2 Mal editiert, zuletzt von thgoebel (14. April 2024 um 18:43)
  • In practice, I would advise against such tinkering and will therefore not provide any further information.
    This would be the end of this forum: Tinkering (with hard- and/or software) is the clue for evolution. Otherwise we should refer to the manuals provided by Shelly Europe Ltd. …
