SHELLY 2 PM How to connect to a push button
  • Hi,
    I bought a shelly 2PM and it works great with a roller shutter.
    I found the schema when i have a UP and DOWN cable to the engine but i d'on't find the solution when you have only one cable to the engine (behind my push button)
    Someone can help me?
    thanks
  • Seems to be some discrepancy exists between these two statements:
    and
    A roller shutter with ONE button only needs another Shelly actor as a Shelly plus 2PM. And it’s not sure that a proper solution exists with such a roller shutter motor.
  • At first, you should describe the device and its possibilities! After that, we could think about a solution.
  • i'd like open my garage doors.
    From now i have a button in the garage.
    If you press on it it goes DOWN ==> STOP ==> UP ==> STOP ==> ....
    Behind this button i only have two cables (L + another one that goes to the engine)
    I ned to keep this button but i'd like a shelly module to open it from my phone.
    I hope you have enough detail to help me :)
