How to deactivate the ADC
  • Hi,
    in my application I am using the UNI to smartify my doorbell. For this (detection that doorbell button was pressed) I only use the binary input 1.
    Unfortunally the UNI is sending secondly new voltage values to HA.
    Does somebody know how to disable the ADC on the UNI?
    Ok, I have left the ADC input floating. May it stop when being shortcut to ground?
    Bernd
  • Welcome to the forum!
    Give it a try and check it! And tell us about…
    Please be aware that pin 3 (ADC) has to be connected with pin 6 (SENSOR GND)!
  • Hi,
    thanks for your quick responses.
    @#3: thx, this stops the logging in HA :thumbup: (but I want to stop the sending of the ADC values).
    @#2: I will take care (and mind the correct ground) and come back with an answer.
  • Hi,
    now I tried again with PINs 3 and 6 shortcut. Result: no change. Even voltage range is the same. I get secondly updates.
