Shelly2.5 not discover in the app
  • Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen. Hi,
    I have a several shelly2.5 for the rollers-sutters, but i had a issue with one item, every time it lost connect to wifi. after power off and reset it again, it appear and i connect it again, but few days after it happen another time.
    this last time, i couldn't connect it to app, after reset, i can see it in my wifi list (phone), but discovering in the app by wifi cannot find it. I've check on my Router and it's not connected. tried several time by powering off and reset without result;
    What did i miss ? or is there any other solution can i tried to fix it.
    Best regards
  • Most likely, some electrolytic capacitors did run dry over the years:
    thgoebel
    15. April 2022 um 10:34
  • Très probablement, certains condensateurs électrolytiques se sont asséchés au fil des années :
    thgoebel
    I guess i need to replace it (there's a small noise).
    Thank you for Feedback
  • Your welcome! The capacitors are easily replaced if some skills in soldering and desoldering are available. After that, Shelly is like new…
