Invert the output voltage
  • Hello...i'd like to use a Shelly to order a watering valve. To open the valve I need to send a +9V impulsion, then, to close it requests a -9V impulsion (on the same valve inputs, but the tension is inverted).
    Is that easly feasible?
    Thanks to all 😃
    Cheers
  • Welcome to the forum!
    Could you please indicate the type of the relay and its producer!?
  • Sorry, a misleading typo in my question: Would like to get information about the valve!
  • Dieses Thema enthĂ€lt 5 weitere BeitrĂ€ge, die nur fĂŒr registrierte Benutzer sichtbar sind.
