two channel relay control
  • Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen. Hello,
    is it possible to control a two-channel relay like the one in the picture using Shelly UNI? Alternatively, does anyone have a wiring diagram? Everything will be powered by a 24v DC source.
    Thank you in advance
    Einmal editiert, zuletzt von Michal Soppe (6. März 2024 um 09:32)
  • Welcome to the forum!
    The depicted relay module has obviously optocoupler inputs, which are selectable for switching with high or low level. Thus, the input current is very low. The outputs of Shelly UNI will drive this module directly!
  • May be. Don’t have a datasheet for the relay module. Give it a try and check it!
