Push On/Off with Rotary Dimming compatibility
  • I've not seen any posts mentioning the Dimmer2 working with rotary switches. Is it compatible?
    My existing wall switches are Push On/Off with Rotary Dimming modules from https://www.varilight.co.uk/dimmers/v-pro.php - and I'm not having much look with them working so far. What button type configuration needs to be set in the Shelly app?
    The existing setup is 2 way wiring with a dimmer on one wall and a straightforward on/off push button on the other wall.
  • Unfortunately, two dimmers won’t work together at one light, whatever dimmer type it would be. Thus, your plan will not work. You’ll have to replace the rotary dimmer with a simple two way switch to implement dimming with Shelly. Or - much better - replace the rotary dimmer AND the two way switch with push buttons. This allows user-friendly dimming with up and down buttons.
    There is only 1 rotary dimmer involved, the other switch is a simple on/off in the 2-way setup.
    Replacing one rotary dimmer with some push buttons on the wall face plate of 4 switches isn't ideal - creating more work and cost for a retro fit.
    So just to clarify, the Dimmer2 SW input doesn't support variable rotary dimmer switches at all?
