Shelly TRV doesn't close properly after opening
  • One of my TRVs does not close the valve properly. When being closed the radiator keeps heating up. Recalibration (most of the time) solves the issue, but this needs to be repeated every time that the valve has been opened...
    Setup
    TRV receives temperature correction from an HT.
    COIOT logging to Home Assistant.
    Force close/move enabled.
    Auto calibration disabled (advice from support).
    SW 2.2.3rc3 (advice from support)
    Does anyone have other tips?
    I need a solution quickly as currently this setup is unreliable (have to stay at home to heat my house...).
  • Welcome to the forum!
    To solve the issue, you could:
    Send the defective TRV back to the seller, or have a look inside: This
    thgoebel
    5. Februar 2024 um 20:10
    is an assembly error which may cause the same symptoms.
  • Thanks for the quick reply.
    I'm not that experienced in taking stuff apart (and back together). Would a TRV with such an error still function and perform calibration?
  • No. Calibration will fail.
