Do Shelly 2.5 capacitors fail with 120 volts (US split phase) or only with 230/240 volts?
  • Drying-out of capacitors is mainly induced by temperature. Temperature inside a Shelly 2.5 is independent from voltage, cause the half voltage is accompanied by the double current, if power consumption of Shelly and/or attached appliances is the same. Thus, it is very likely that capacitors do have the same life cycle in a 120V grid.
