Control 2 lights with 2 push buttons
  • Hello,
    I was planing to control 2 separate lights with two separate push buttons using Shelly plus 2PM, but I can't find the adequate menu option in the web interface.
    In "switch" profile there is no option to use dual push buttons.
    I can get it to function using "cover" profile, but there is a time limit of maximum 360 seconds and after that the light turns back off.
    Is there any other solution I am not aware of?
    Thank you
  • Welcome to the forum!
    To your issue: due to the fact, you want to control two separate lights with separate buttons, you’ll need to
    (a) use switch mode, not cover mode,
    (b) to set ‘button’ in switch/button type menu, and
    (c) to wire the buttons and lights adequately:
    629-ar768-tasterschaltung-shelly-plus-2pm-png
