Unable to access web UI from mobile browser?
  • Title says it all. I used to be able to access the web interface of all my Shelly devices from my phone's browser (iOS Chrome / Firefox / Safari / whatever) – but now with the current firmware I can *only* access the web UI from a laptop.
    Is this an intentional change or has something broken? Devices with older firmware (such as my RGBW dimmer) can still be accessed from a mobile browser. This is kind of a pain, keen to find out what's happened. Thanks!
    EDIT: Solved...
    RE: Unable to access web UI from mobile browser?
    Einmal editiert, zuletzt von disuye (20. Februar 2024 um 12:14)
  • You’ll need IOS 17!
  • Why do I need iOS17 to view what is effectively a webpage? Not being sarcastic, just genuinely curious what has changed?
    Einmal editiert, zuletzt von disuye (16. Februar 2024 um 13:39) aus folgendem Grund: EDIT: Also, it's a bit of an oversight from a company that sells devices allowing users to RETROFIT automation to old existing home hardware, but then require the latest iOS (which isn't always available to use on older mobile devices; mobile device often being re-purposed for home automation duties).
