Dimmer 2 works without switch?
  • I have bought a Shelly Plus 1 for switching a light with 4 GU10 LED bulbs. I have no wall switch so I use the app only to turn on the light.
    Unfortunately the light is too bright. So I think a Shelly Dimmer (2) is the solution for this. I understand the LEDs must be dimmable and the four LEDs should be 10W minimum. I don’t know if I can use a Dimmer without a wall switch/dimmer.
    FYI: I have a Live and Neutral wire.
    Einmal editiert, zuletzt von janmostert (14. Februar 2024 um 11:29)
  • Welcome to the forum!
    You may install a Shelly Dimmer2 without a wall switch. Lights are turned on and off or dimmed by the Shelly App or WebUI only.
