Shelly 1PM plus to control ventilator with light indicator toggle switch
  • Hello All,
    My bathroom as a ventilation toggle switch with LED indicator to know that the vent is on.
    like this:
    i´ve Shelly 1PM Plus to control it. with no success fowling the instruction...
    by "accident" this seems to work:
    i'm WORRIED this will damage the Shelly device...is this wiring OK?
    i've SW-LED-Neutral... ( i've read somewhere that SW as to be connected to L )
    it is working...but the led indicator only pops/light if the toggle switch is turn on,
    better that this... only... if i can find the way to see the led on/off signal with the ventax on/off set by the 1PM+
    CAN I DO THIS"?"?
    Thanks in advance.
    2 Mal editiert, zuletzt von LUIS2MM (9. Februar 2024 um 16:33)
  • LUIS2MM 9. Februar 2024 um 16:33
    Hat das Label von Shelly 1PM auf SHELLY PLUS 1PM geändert.
  • This is a well known issue, resulting from the fact Shelly relays are activated both with live AND neutral potential. Details are to be read in this thread (unfortunately in German language):
    thgoebel
    2. September 2021 um 18:57
    To solve the issue, you would need a resistor between the switch and the SW input:
    I would be glad to help you to get a well isolated resistor ready for installation!
  • I've been looking to the tread you mention before and try to translate it
    i don't understand why my actual wiring is working... and is it harmful?
    and i don't understand why you don't use the Output to give Live to power the vent.
    ...are you sure that your diagram wont give current to the toggle led indicator.
    ...if the resistor stops the LED to signal when it's OFF, how it can it signal when shelly turns on the vent. the manual switch is off and line as a resistor as no current in the LED
    something like this makes any sense?:
  • No light to switch on and off? Assumed, the light symbol should represent a light and the vent shall be controlled with the Shelly. Hence, I didn’t draw the vent in my sketch…
    It would be brilliant to get your aim in a more detailed version!
    ...the vent should be controlled with shelly and manual switch
