Shelly 1 Gen 3 mini with 240v led driver
  • Hi,
    I have recently tried to use a mini gen 3 to switch off and on a led driver. When wired up I found the led would flash on for a moment then go off. I think I need to use an RC snubber because of the inductive load. Should the snubber be attached at the led driver itself or at the mini gen3.
    Thanks
    John
  • Welcome to the forum!
    Most likely, a LED driver doesn’t represent an inductive load! Except, is is an old fashioned iron core transformer intended for halogen filament bulbs. Hence - in the case you’re using a modern LED driver with a step down converter - a deeper investigation would be necessary to unleash the reason of the failure. In the case of an iron core transformer you should mount a snubber across the transformers terminals.
  • Bit out of my depth I'm afraid, I think I need a snubber because the instructions for the mini gen3 says it needs a snubber with an led driver. I have ordered a snubber and just wondering where it goes in the circuit in order to try it out.
    I've got a few Shelly devices working already but this is my first driving LEDs.
    John
  • Ok, thanks! Obviously, there ain’t no more question…
