Over 24V input on rgbw2?
  • Hello everyone, does anyone know if there is any problem if i supply the Shelly rgbw2 with 25volts or even 26volts?
    Because the power supply and the shelly are a bit far away from the LED strip and i wanna put a bit more voltage to compensate for the voltage drop across the cable
    Kind Regards 😁
  • You should not do that. The shelly and its inner components are designed for a specific maximum voltage. Especially the voltage converter and the capatitors wont like that for long. Power the shelly with more voltate than nominal is risky.
    Jede Maschine ist eine Nebelmaschine. Man muss sie nur falsch genug bedienen 😁
  • 30V DC is the upper limit which should not be exceeded!
