Add-On and voltmeter
  • I tried use Shelly Add-On voltmeter option, but it doesn't work correctly. I tried measure 4 VDC supply and wires was connected to Add-On analog input and GND connections. Shelly app shows voltage changing between 3,1 - 4.6V althought supply voltage doesn't change. What could be wrong? I have connected to same Add-On five ds18b20 temperature sensors.
  • Please turn off ECO mode! And yes - the linearity of the on-board V-f converter isn’t very good! You should not expect 14 bit precision like an ADC chip would deliver…
  • Yes, the ADC of Shelly UNI and UNI plus is much better! It uses the internal ADC of the ESP processors
