Help needed please
  • Hi all. I need to automate a simple situation where I want to be able to see or receive the status of 2 micro switches and be able to remotely momentarily activate any of the 2 outputs and I thought the Shelly Uni would be up to the task.
    I've successfully connected the Shelly to the network and toggle both channels locally on the device but, remotely on the App, only one channel appears. I can separate one input from the output but not the other one. When I separate this input, I'm no longer able to se the state of this input. The other input and output simply doesn't appear.
    I wonder what I'm doing wrong. I've mounted everything on a little breadboard to check the results but until now, I'm not very happy.
  • Welcome to the forum!
    Look in the App for ‘all rooms’ -> ‘hidden devices’. There you should find the second channel!
    Hi.
    Thanks for the reply. I've tried it but it doesn't appear. I can only toggle one output via the app but I can't even monitor the input. The only way I can see the state of the input is when I associate the input with the relay and the the little bar led on the app button will turn green and stay even if I disconnect the relay via the app
  • The little bar is the only way to indicate the state of the input. In the case, the input is attached to the output, the circle ⭕️ should turn from gray to blue when input was activated.
    To the issue with the app:
    Do you see the above? Clicking on ‘hidden devices’ should lay open the hidden channel…
    To the characteristics of the inputs: These are activated by a positive voltage larger than 0,8V above SENS GND (Pin 6). Slightly more voltage is necessary if GND (pin 2) is used (approximately 1,6V).
  • Hi.
    Yesterday I tried but I couldn't find the second channel so, today I performed a factory reset and removed the device from the app. After a rediscover, I can now see the two channels and control them as button separated from the output. I can switch on and off from the app and I can see the led turning green when I power the input. If it keeps going this way I will be satisfied but I would like a little bit more if possible.
    Can I get a notification when a button is pressed (for more than a preset time would be great) If this happens it means that I need to take some action by remotely activating one of the outputs. Could this activation be momentary?
    I hope you can steer me in the right direction, thank you.
