Shelly Pro 3EM not working with latest HA update - Firmware not supported!
  • Latest HA update broke Pro 3EM integration with HA. HA now requires firmware 1.0+ and mime is 0.11.99. I've tried upgrading it but I always get "You are using the latest version of the firmware. Check again."
    Is there ANY way to upgrade Pro 3EM firmware? Thank you.
  • Do you use static IP? If yes is your Gateway and DNS Server set?
    Ist there any Firewall or Child Protection active?
    Yes I use static IP but it's assigned by router via DHCP. No special firewall policies have been set. All other devices connected to the same router have uninterrupted WAN access.
  • Theb you don‘t use an static IP it is still Dynamic assigned by your DHCP server. It‘s only reserverd.
    Have you installed something like PiHole or Adguard?
    No PiHole and AdGuard only as browser extension but no luck even with the extension completely disabled.
    Tried on several devices even the ones without any adblockers or firewalls.
    Tried the mobile app (new) too and it reports that I'm using the latest firmware as well.
