Plug S suddenly dropped WiFi connection
  • Hi,
    meanwhile I am operating quite a bunch of shelly products. So far I have been happy with cost, ease of use and performance of the products, except the Plug S.
    When five months old, one of the Plug S suddenly did't work anymore, simply went off, no more LEDs - over and out. No reset possible.
    Fortunately the dealership replayed it w/o any discussion.
    Today after nineteen months the second Plug S stopped working. I.e. suddenly no longer reachable, dropped off the WIFI network. Device was neither stressed not in a harsh environment.
    Max load ever 600W, inside building, 15ft distance to router.
    Firmware ist the latest 20230913-113421/v1.14.0-gcb84623
    So at first I did a factory reset which worked partially, some of my settings were still there, some were factory reset - strange.
    After Reset device provided WiFi AP
    I logged in 192.168.33.1 and tried switching on/off as a simple connection test. Worked right away.
    Then I tried to include teh Plug S into my local WiFi (I don't use cloud at all) so I entered the credentials of my WiFi network.
    When I hit the save button it took a while until I got an error message "Could not change settings: device could not be reached".
    From this point onwards the device is neither accessible in the WiFi network, nor does it provide its own AP to log on.
    I then can do this reset and trying to save WiFi credentials again and agan, doesn't help. (...and - YES the credentials are the correct ones)
    Anything else I can do ?
    No longer really pleased with the quality of Plug S :o(. Two out of three failed.
  • Welcome to the forum!
    Quite often it happens I get a similar error message after dropping the credentials of my WLAN in the menu. But in almost all cases, the Shelly HAD connected to my WLAN! Thus, I check this (e,g. with the App ‘Net Analyser’ on my tablet). Is the Shelly online, I don’t care about the error message. Seems to be caused by some delay in information processing…
  • thgoebel txs for the hint. I indeed missed to mention... I always doublecheck if the Shelly did connect to WiFi or not - no matter what the screen is telling me - it did not connect.
    For checking I try a simple ping first, then Quickscan App on Android which usually is good enough. If devices can't be reached/seen they are not connected.
    For tough cases I check my Network Monitor NTOPNG and wireshark. But this Shelly Plug simply doesn't work.
  • Seems to me this Shelly has to be sent back to the distributor…
